Noob question I'm sure but i cant locate it in the search - Changing ceiling height changes moves the floor up, not the ceiling down
AaronS71188
Go to solution Solved by robdyck,
Would like to keep the foundation locked - is this a setting somewhere that i'm missing?
I am changing the ceiling height in one room on the 1st floor but it is raising my foundation footer instead. See screeshot
2 hours ago, solver said:
You don't have a foundation. Consider building one instead of marking your first floor walls as Foundation and Slab Footing.
What do you want to happen on the 2nd floor when you drop the 1st floor ceiling? What type of ceiling structure does the room have?
The second floor is directly on top of that next level. The roof will drop considerably and is not accurate right now, i just didnt get to that part yet. Working on creating the as-built model for our work building to prep for an addition or 3 in other areas. Aside from the perimeter, nothing else has been worked on in there.
Thanks for your help!
