Floor height dimension issues
KAustin
55 minutes ago, KAustin said:
My thought was that the first floor "Finished Ceiling" height should be 120"
If you are specifying pre-cut studs your ROUGH CEILING HEIGHT needs to be set at 121.125" The finished ceiling height is dependent on ceiling drywall thickness and flooring thickness, so use the rough height based on the lumber you are using, or that you expect to use.
