lavorhaynie Posted May 6, 2021 Share Posted May 6, 2021 Attempting to import a DWG. Selected File>Import Drawing (DWG, DXF)... This is in a New plan right after opening CA. Chief thinks the dialog is open but it is nowhere on the screen. I've attempted this several times to ensure the dialog is not behind the CA window. End up having to close CA via Task Manager. Any help would be greatly appreciated. Best regards, LaVor Link to comment Share on other sites More sharing options...
MarkMc Posted May 6, 2021 Share Posted May 6, 2021 If it could have previously been opened on another svreen that's not present? Then try preferences, general panel, save dialog position and size, change to never might work. Otherwise no idea. Link to comment Share on other sites More sharing options...
lavorhaynie Posted May 6, 2021 Author Share Posted May 6, 2021 Thank you gents for your help. Got the dialog back using the Preferences>Reset Options>Reset Dialog Sizes option. Thanks again! 1 Link to comment Share on other sites More sharing options...
