How do I define an area as a room?
bdillard
Go to solution Solved by pitchfork5iron,
Hello,
I'm using the auto roof generation tool.  I'd like to have a partially covered deck.   It is probably obvious but how do I designate a portion of my deck as a room so I can cover that section of the deck?    I've circled in blue the section I'd like to designate as a room.   I may be asking the wrong way to do it but I'd like to extend the roof over the area I've circled.
Thank you.
2 minutes ago, pitchfork5iron said:
Use an invisible wall to define the area, then adjust the room specification DBX's as needed. Your blue line area will need the "roof over this room" checked, and the area outside will obviously need that unchecked.
Thanks.
The nice thing is that your answer is accessible now to someone else with the same question.   I haven't tried it because I had found a similar solution when you were writing your helpful response.   So other newbies like me can quickly do this same thing.    I've found myself going back to my old post 6 months later as I forgot how to do something.
 I threw in some posts but people get the idea.
