DougDM Posted May 5, 2021 Share Posted May 5, 2021 Hey all, hope all is well. So even with all layer on, can't find the fascia board. see attached All other fascias are showing. Any ideas? I've tried rebuilding, deleting and new roof plane, Tried manual and Auto. This one is just now showing. I'm sure it's a setting I'm missing somewhere. Thanks, Doug Link to comment Share on other sites More sharing options...
rgardner Posted May 5, 2021 Share Posted May 5, 2021 I am assuming you double checked the size for the fascia trim for that roof planes as I am guessing you are still drawing manually? Almost looks like there is a faint line there but hard to see in standard view. Link to comment Share on other sites More sharing options...
DougDM Posted May 6, 2021 Author Share Posted May 6, 2021 20 hours ago, rgardner said: I am assuming you double checked the size for the fascia trim for that roof planes as I am guessing you are still drawing manually? Almost looks like there is a faint line there but hard to see in standard view. Yes I did, It's the same as all the other roof planes. Still drawing manually?.... I do, always have and always will. Link to comment Share on other sites More sharing options...
DougDM Posted May 6, 2021 Author Share Posted May 6, 2021 19 hours ago, solver said: Attach plan file so someone may troubleshoot. I fixed it, this plan file has several conceptual roof planes within the same area over the deck. I.E. different roof styles over the deck. One looks the same as shown but has an extended overhang section at the eve to cover a cantilevered grilling area (not shown in the attachments). Two roof planes were occupying the same space and I believe the fascia's were fighting for the same space.. I changed the over hang of the one and it appeared. All I know is its fixed, thanks guys for looking. The attachment shows the other roof occupying the same space as the first. The extension I think was cutting into the straight fascia there by hiding it. Link to comment Share on other sites More sharing options...
