Import SAVED PLAN VIEW and LAYER SET at same time
dshall
Suppose you are working on a plan and you want to import a SPV and its corresponding LAYER SET from another job,  simple go to IMPORT SAVED PLAN VIEWS and select the project that has the SPV you want and you get the  corresponding LAYER SET.
Pretty Darn clever of CA.
1824186244_ScreenShot2021-04-30at5_46_27AM.thumb.png.e2bc84a7b2d6835c98a831b3d95af12d.png
Just as an FYI, I believe the rule is that the program will import the layer set as long as there is not already one using the same name in the plan.  It will also import all of the other annotation defaults (such as dimensions, text, etc.) as long as they are not in the plan either.
