reset to default floor height doesn't work
Lighthouse
Hi,
I changed some basement floor heights manually.  I then went to "reset to defaults" and selected "foundation" and "change bottom wall height", but it doesn't change it back to the default.  Is it possible to reset defaults for settings (floor height) that have been changed manually?  If so, why doesn't "reset to default" work?
thanks
I am confused with what you are describing here.  Maybe a terminology issue.  Can you post some screen grabs to clarify?
