Dormer Wall Issue
Go to solution Solved by solver,
Having an issue with my dormer walls being cut by the roof line at the bottom. I have selected the option for the roof to cut the wall at the bottom, and I've made sure my roof is touching the dormer walls but still won't work correctly. Any ideas on what I am missing?
Thanks,
Common problem with lots of intricacies in dormers.  It is not always the same problem.  Best practice for this type of help would be to include the .plan file.
23 minutes ago, solver said:
Please check your messages.
For questions like this, attaching the plan file (close Chief first) will make it much easier for someone to help.
I've tried attaching my plan but it's too large even after sending it to a zip folder. Any tips on how to get the file smaller so I'm able to attach?
Make a copy and delete what's not needed.
All Off layer set. Display fixtures, electrical, cabinets etc. Group select and delete.
    29506
    Berretta969mm
    Berretta969mm
