aurorainteriors Posted April 16, 2021 Share Posted April 16, 2021 Hi All. Still new to the program and figuring things out. I have built an automatic roof and am trying to modify it to be a gable roof instead of the default hip roof. I have watched the various videos on how to do this as well as read through forums and have not been able to figure out why my roof will not adjust to a gable after changing each wall to be a gable setting. I've attached screenshots and uploaded the file. The client only wanted a model for purposes of seeing a new deck/stair option and paint color so the roof isn't the most important thing but I still want it to resemble their house. Thanks, Krissy Chief Architect Premier X12 (64 bit) Bristol House.plan Link to comment Share on other sites More sharing options...
aurorainteriors Posted April 16, 2021 Author Share Posted April 16, 2021 2 minutes ago, solver said: Is Auto Rebuild Roofs on, or have you checked Build Roof Planes in the Build Roof dialog? Yes, Auto Rebuild Roofs is on. Link to comment Share on other sites More sharing options...
aurorainteriors Posted April 16, 2021 Author Share Posted April 16, 2021 16 hours ago, solver said: Thank you SO much Eric! I really appreciate you taking the time to look into this and record how to fix it. That worked for me! Link to comment Share on other sites More sharing options...
aurorainteriors Posted April 16, 2021 Author Share Posted April 16, 2021 15 hours ago, solver said: Here's an actual image of the house. I've been playing around and can't figure out how to get the simple sloped roof above the garage or how to change the roof above the bay window to connect to the roof on either side of it. Here's my updated model. Bristol House.plan Link to comment Share on other sites More sharing options...
aurorainteriors Posted April 16, 2021 Author Share Posted April 16, 2021 14 minutes ago, solver said: That roof should easily auto build. Set your roof defaults, change walls to gable etc. If you used the Bay Window tool, you will need to delete it and draw in your own bay. Make your deck small like the one shown and set it to have a roof and ceiling. I figure out what was going on with the roof over the garage. Looking at the photo of the house again I'm noticing the roof over the second floor over the garage- the roof is actually not centered within the middle window but centered between the first angle of the bay window and the other exterior wall. Not sure how to update the roof to be centered in this location? Link to comment Share on other sites More sharing options...
aurorainteriors Posted April 16, 2021 Author Share Posted April 16, 2021 Just now, solver said: So the roof will build over it. The only issue with that is the client wants the deck to be large now and not small like how it currently is- how do I work around that? Link to comment Share on other sites More sharing options...
GeneDavis Posted April 16, 2021 Share Posted April 16, 2021 Seeking services? Link to comment Share on other sites More sharing options...
