Celling doesn't follow the deck
Hi Everyone!
I'm quite new in CA. Recently I run into a problem, and I can't figure out what causes this strange ceiling behavior.
I have a balcony and a deck and and one room underneath it. The deck has a ceiling, but a small piece sticks out in one corner  (I attached two pictures).  Can anyone help meg to get rid of this unwanted ceiling piece.
Thank you
Check how the corner intersection of the walls that define the room under the balcony are joined.  Or post the plan file and one of the experts will take a look for you.
16 minutes ago, adam82 said:
Can anyone help me
Please check your messages.
Attaching the plan file (close Chief first) will help someone troubleshoot.
Hi Chopsaw,
There was an issue with that intersection indeed, I moved the 'Room divider' a little bit further and the strange ceiling disappeared.
Thanks you!
    29506
    Berretta969mm
    Berretta969mm
