Debbie Posted March 18, 2021 Share Posted March 18, 2021 My foundation is partially above grade and I am using a pony wall. When I show a cross section the concrete portion of the pony wall is also appearing as wood. However, when I open the wall all the components are correct. Any advise? Thank you in advance. Link to comment Share on other sites More sharing options...
Debbie Posted March 18, 2021 Author Share Posted March 18, 2021 I am using X12 Link to comment Share on other sites More sharing options...
Debbie Posted March 18, 2021 Author Share Posted March 18, 2021 Thanks for the correction. The backclipped cross section is working, but not the cross section elevation. Debbie Premier X12 iMac, 3.2GHz, 16 GB, Radeon Pro 560x 4GB Link to comment Share on other sites More sharing options...
Chrisb222 Posted March 18, 2021 Share Posted March 18, 2021 Looks like you're seeing the wood wall beyond the concrete wall. A standard cross section will continue infinitely, and the cut objects are hollow, so you see beyond them Link to comment Share on other sites More sharing options...
Debbie Posted March 18, 2021 Author Share Posted March 18, 2021 Thank you. Link to comment Share on other sites More sharing options...
