Debbie
Foundation Pony Wall
My foundation is partially above grade and I am using a pony wall. When I show a cross section the concrete portion of the pony wall is also appearing as wood. However, when I open the wall all the components are correct. Any advise? Thank you in advance.
Thanks for the correction.
The backclipped cross section is working, but not the cross section elevation.
12007610_ScreenShot2021-03-18at11_42_43AM.thumb.png.1fb7a0ce47e850328f08647d77b65343.png
Debbie
Premier X12
iMac, 3.2GHz, 16 GB, Radeon Pro 560x 4GB
Looks like you're seeing the wood wall beyond the concrete wall. A standard cross section will continue infinitely, and the cut objects are hollow, so you see beyond them
    29350
    sea_lyons
    sea_lyons
