Nicu101268 4 Posted March 4 This thing is possible? I didn't find anything in Help. Share this post Link to post Share on other sites
Alaskan_Son 2608 Posted March 4 Go into Tools>Toolbars and Hotkeys>Customize Hotkeys, search for "Spin" and you should find the Start Camera Spin tool. Assign a hotkey if one isn't already assigned. You can then simply hit this key to start the camera spinning. The spin speed can be controlled by opening your camera specification dialog and adjusting the Incremental Rotate Angle...the smaller the angle, the slower the spin. Note that the spin speed will only adjust the next time you start the spin (spin speed will not change if you change number after you have already started the spin). You can also simply initiate the spin using your mouse by letting go of the mouse button while actively rotating the camera (done with a sort of flick of the wrist), but the spin speed is extremely difficult to control that way. 1 Share this post Link to post Share on other sites
Nicu101268 4 Posted March 4 @Alaskan_Son, thank you very much! I have already assigned the key combination Ctrl + Alt + S (Spin). The spin can be reversed by pressing Ctrl + Alt + S again. Very cool! 1 Share this post Link to post Share on other sites
