builtright3 Posted March 2, 2021 Share Posted March 2, 2021 I rotated my plan 180 degree but now when I put text in it's always upside down. Is there a way to fix it so I don't have to change it every time I put text in? Any help would be appreciated. Thank You Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 2, 2021 Share Posted March 2, 2021 Sounds like you must have used Rotate Plan View. That tool essentially just rotates the entire drawing board. You probably wanted to rotate the building and as such, should set the Plan View rotation back to zero and then use Edit Area to rotate the building and any other desired drawing elements. Link to comment Share on other sites More sharing options...
builtright3 Posted March 2, 2021 Author Share Posted March 2, 2021 1 hour ago, Alaskan_Son said: Sounds like you must have used Rotate Plan View. That tool essentially just rotates the entire drawing board. You probably wanted to rotate the building and as such, should set the Plan View rotation back to zero and then use Edit Area to rotate the building and any other desired drawing elements. Thank You! As usual, you saved me again! Link to comment Share on other sites More sharing options...
