Arches brick wall (on asphalt)
 is there a better way? The width of arches brick wall would be the size of window or size of 2 windows I’ll attach pic of building. It would be better to build and dig up for proper foundations to support 4ft of brick wall with arches, but can I get help with designs of the arches or possibly Guidance to options. Thank you. Ernest.
Yes you don't want something that heavy falling on someone so proper attachment to footings would be advised.
As for drawing it in chief.....   This is just an 8" concrete stem wall with two elliptical arch doorways and a wall cap.
Is that the look you are after ?
48 minutes ago, kMoquin said:
Sounds like someone needs an engineer and possibly a copy of ADAAG
You’re right Kmoquin, great work btw. as for engineers; two came out. One specialist structure steal engineer for inside being that we’re taking walls out inside. He advised it is possible for  brick arches outside just to get blueprint for city inspector. the other did not advise at all with different contractor.  I drew some drawing just not sure what it acceptable as blueprint for the city?  the guy comment above gave great illustrations and I thank you both!
You nailed on first comment Chopsaw, thank you. It mean a lot. I drew this similar site on paper and gave to structure steal engineer and he advised to get blueprints to give to the city I’m just not sure what is acceptable as for blueprints.
Oh that’s great advice ahead! The plan would have the original door access way, its  asphalt  surface. Would see to keep new dug foundation from front entrance. Hope thats what this  article and you are referring to?
Thank a lot again! -Ernest
    29811
    mserleth
    mserleth
