Lower Part Of Stairs Open - How To Terminate?
Skip_D
Hi,
Common situation.  Stairs leading to 2nd floor, partially open for the 1st 4-5 treads at the bottom.  Railing on the open side terminates INTO the end of the wall at about the 4th or 5th tread.  Therefore, the stair case is approximately 5" wider at the bottom.   NOT starter treads.  How does one do this?
I've attached a quick CAD image in pdf for clarification.
thanks.
