Skip_D Posted November 28, 2014 Share Posted November 28, 2014 Hi, Common situation. Stairs leading to 2nd floor, partially open for the 1st 4-5 treads at the bottom. Railing on the open side terminates INTO the end of the wall at about the 4th or 5th tread. Therefore, the stair case is approximately 5" wider at the bottom. NOT starter treads. How does one do this? I've attached a quick CAD image in pdf for clarification. thanks. Link to comment Share on other sites More sharing options...
Skip_D Posted November 28, 2014 Author Share Posted November 28, 2014 Here's the attachment ... Open Stairs.pdf Link to comment Share on other sites More sharing options...
rlackore Posted November 28, 2014 Share Posted November 28, 2014 Winders are the answer. Check the Reference Manual beginning on page 536 for a detailed explanation. It's not a perfect solution, but it should get you started. Link to comment Share on other sites More sharing options...
Rosco2017 Posted November 28, 2014 Share Posted November 28, 2014 Read this thread. It's pretty good! https://chieftalk.chiefarchitect.com/index.php?/topic/2295-fantastic-new-solution-found-re-how-do-you-show-partial-open-railing-stairs-and-how-to-show-the-door-to-the-basement-stairs-underneath/ Link to comment Share on other sites More sharing options...
