jmyers Posted February 22, 2021 Share Posted February 22, 2021 I have recently purchased HD Pro and have made great strides in learning the software. Obviously, I have a long way to go, but I have progressed significantly since first purchasing. For users who have used both Premier and HD Pro, I have a few questions regarding the ease of use between the two. When comparing the products, it's very to easy to see that Premier has much greater capabilities and options. With that understanding, how difficult is Premier to learn in comparison to HD Pro? Is the learning curve much steeper? Is Premier much more difficult to use, due to the advancements and capabilities? Thanks to all who respond! Link to comment Share on other sites More sharing options...
lbuttery Posted February 23, 2021 Share Posted February 23, 2021 HD PRO is Premier lite - about 20% of the tools and features what you learn for HD PRO will work for Premier but Premier has so much more so yes the learning curve is "bigger" and maybe even "harder" due to the extra features since Hd PRO has many of the same manual tools following the ChiefTalk forum can be of benefit just understand the limitations of PRO and when posting on Chieftalk be aware that some solutions may not apply to PRO CA does give 100% credit towards upgrade to Premier when you decide you need it Lew Link to comment Share on other sites More sharing options...
jmyers Posted February 23, 2021 Author Share Posted February 23, 2021 16 hours ago, lbuttery said: HD PRO is Premier lite - about 20% of the tools and features what you learn for HD PRO will work for Premier but Premier has so much more so yes the learning curve is "bigger" and maybe even "harder" due to the extra features since Hd PRO has many of the same manual tools following the ChiefTalk forum can be of benefit just understand the limitations of PRO and when posting on Chieftalk be aware that some solutions may not apply to PRO CA does give 100% credit towards upgrade to Premier when you decide you need it Lew Thanks Lew and Eric! Link to comment Share on other sites More sharing options...
