Error: Cannot mix imperial and metric units in a layout page
LSTECYK
Hello
Having an issue trying to create layout pages of a kitchen plan. When I send to layout I get the error message "Cannot mix imperial and metric units in a layout page" and the info is not sent to the layout. I've tried removing dimensions, turning them off in display. I've checked preferences and default settings to make sure I'm working in Imperial which I am and which is what I want.  I have no idea what is coming up as metric in the model that is causing this.
Thanks in advance for your help,
L
2 minutes ago, LSTECYK said:
Hello
L
Did you do this drawing using a metric template?
Well I think I solved it. I copied everything and pasted it into a new plan and sent it to a new layout which worked. I must have brought some metric setting into the model when I copied something from a different model over...even after I deleted the object I guess it had some metric setting attached to it who knows. I tested a previous version of my model and it worked fine so it had to be something to do with the recent changes I made. No time to further dissect what I did wrong I'm just happy its fixed. Thank you for your help!
