Alaskan_Son Posted February 16, 2021 Share Posted February 16, 2021 12 minutes ago, pdiaz4 said: So the left corbel is correct but still isn't blending in. That's because you painted the wall on the left side with a different siding material. If you are going to change the material type being used on you exterior walls then you should really create a new wall type. At any rate, what you need is for the finish layer of the front wall to run all the way through to the end. To get that to happen, select the wall and then click on the Edit Wall Layer Intersections tool in the Edit toolbar, and then drag the finish layer through to the end. Link to comment Share on other sites More sharing options...
pdiaz4 Posted February 16, 2021 Author Share Posted February 16, 2021 13 minutes ago, solver said: Thank you so much, finally got it!! Link to comment Share on other sites More sharing options...
