HStone
Field stone wall
How can I create a heavily textured surface such as a field stone wall that reads in 3D? This would require, as an example, that the outside corner of a field stone wall show stones projecting out of the plane of the wall.
You should post this on the Q&A forum if you want people to respond with help for you.  This forum is to offer tips you know that will help other users.
It's tough - unless you want to import some kind of geometry or use polygons, you'll have to be satisfied with the 'bump' map that chief includes.
You could also try out Blender - I've just started using it and exporting my Chief models - and then in blender you can do all sorts of neat things to the geometry like add really great textures, create offsets/displacement like you've described, and a bunch of other stuff. Still getting into it but seems like, for me, this is going to be a part of my future workflow. Good luck
    29364
    Brian-Ingrained
    Brian-Ingrained
