J_Ward Posted January 15, 2021 Share Posted January 15, 2021 Is there a way to keep the inside AND outside lights on in this view? I can manage to do one or the other depending on where I start my camera view. This was drawn in X10, but I do have X12. If it matters. Thanks Link to comment Share on other sites More sharing options...
ericepv Posted January 15, 2021 Share Posted January 15, 2021 You can turn lights on and off and adjust other properties in the 'Adjust Lights' panel. It is accessible from the drop menu on the 'Adjust Lights' button in the menu bar (look for the light bulb symbol). You should also click on 'Light Set' in the DBX for your camera. Here's a good overview from the Knowledge Base https://www.chiefarchitect.com/support/article/KB-00777/working-with-light-sources.html Link to comment Share on other sites More sharing options...
