Mijo1069 0 Posted January 14 Hello Software version Home Designer Pro 21. When setting up, the Drawing Sheet always defaults to 22" x 17" I want a bigger sheet to add more than one or two drawings. I check the pasted drawing and the same defaults show on a sheet 22 x 17 so I have to reduce the drawing to 1/8=1' in order to fit more than one drawing. What I'm I doing wrong or not doing? or will the desired size will happen at printing? Thanks in advance. Share this post Link to post Share on other sites
Mijo1069 0 Posted January 14 Sorry, I'm new to this. I tried looking up how to delete the thread but unable to. Share this post Link to post Share on other sites
lbuttery 192 Posted January 15 Mijo: NOTE: HD PRO users can benefit from following Chieftalk as well as Hometalk since PRO has many of the manual tools that Chief Premier has when posting be sure to note you are using PRO and when reviewing threads be aware of the limitations of PRO as not all info will apply to PRO Lew Share this post Link to post Share on other sites
