RicatRandM Posted December 16, 2020 Share Posted December 16, 2020 I'm trying to change the reveal on Lap Siding from default to 6". I must be missing something because the changes I make are not holding or showing up? Any help is much appreciated. Link to comment Share on other sites More sharing options...
Gawdzira Posted December 16, 2020 Share Posted December 16, 2020 Throwing out a guess as to what you are doing...If you have only changed the material on this tab, you are only changing the pattern which will show in Line Drawing or Vector. You need to proportionally adjust the Texture to match your changes. Link to comment Share on other sites More sharing options...
