SteveByars Posted December 15, 2020 Share Posted December 15, 2020 Some objects, like GFCI's, toilets with a handle, or kitchen faucets with a lever control are tedious to locate. When inserting them into a plan they are located based on the center of the symbol, including the 'GFCI' label or the side handle. Is there a way to redefine the 2D insertion point of these symbols? Thanks! Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 15, 2020 Share Posted December 15, 2020 Of course, in order to modify anything for a Chief supplied symbol you will need to copy it to your user library. The best thing would be if Chief Content made those modifications to the symbols and provided those fixes via a Library update. 1 Link to comment Share on other sites More sharing options...
