MarkDW
It seems if the window schedules can calculate the rough openings by adding the 1/2 inch to the unit size... or whatever I set up in the framing option to be... there's got to be a simple way to display the R.O. at each window... but how?
I know nothing about Ruby stuff nor creating text Macros. Do I need to use one of these? If so, how? I have no idea what to do! And three calls to CA tells me they aren't going to help. I'm rather frustrated!
I've seen a couple posts and even some code on a post and thought I would be able to make changes to it to get the outcome I want - but no luck. I'm doing something wrong, I guess.
Here's an example of how I'd want the rough opening displayed (under each window)... R.O. 3'2 1/16" x 6'0 7/8"
In addition to the R.O., I'd also want the Andersen window name/code above, or below, the rough opening. Adding their specific window name/number is my next issue. Well... that, and figuring out how to get all their sizes/windows in the system!
Following is the code I found. If this is the code I need to use... can someone tell me how/where to apply it?
number = height + rough_opening_top + rough_opening_bottom
divisor = 1/16.to_f
a = ((number/divisor).round*divisor).divmod(12)
feet = a[0]
inches = a[1].floor
if a[1].modulo(1) == 0
fraction = ""
else
fraction = " #{a[1].modulo(1).rationalize}"
end
"#{feet}'-#{inches}#{fraction}\"".reverse.chomp("-'0").chomp(" 0").reverse.chomp("-0\"")
