tjsage1 Posted November 28, 2020 Share Posted November 28, 2020 First floor shows up but my second floor level does not. Railing is in place but not the structure, thank you. BLANCHARD-REND-1.plan Link to comment Share on other sites More sharing options...
Chopsaw Posted November 28, 2020 Share Posted November 28, 2020 You will need to establish a defined room for the automatic decking to generate. Railing is not connected to exterior wall on north side and it appears you will need a room divider at the south end to connect to the exterior wall and set you room to be a deck with the proper levels and you should be good. Link to comment Share on other sites More sharing options...
tjsage1 Posted November 28, 2020 Author Share Posted November 28, 2020 Thanks Chopsaw, finally worked. Link to comment Share on other sites More sharing options...
