discovery-ed
Auto Dimensions Help
I am modifying a plan that someone else started... The auto dimensions are turned ON but I guess they deleted the specific auto dimensions on the plan.  Is there a way to have the system reformat/create all of the auto dimensions?
What happens when you use the Auto Dimension tool?
Nothing happens...  It is turned on but apparently they deleted each individual auto dimension instead of just turning off that layer.  I received your note and will search the different areas for a solution. X12 is the version.
Did you try the All On layer set -- and make sure all layers are on?
Even if you delete all the auto dimensions manually -- one by one, the Auto Dimension tool will place new ones.
6 minutes ago, discovery-ed said:
X12 is the version
It's helpful to have that in your signature.
Open the Auto Dimension tool and check the box for refresh. Once an auto dim is deleted, it turns the tool off, this will turn it back on.
    28868
    snakes911
    snakes911
