Roof gap/Missing siding
srjbb97
Hello,
I am still learning this program, but have come across an issue I am having trouble with.. When we done the roof and got it just about how we want it, the side profiles are missing the siding. I have posted a picture as reference. I am using Chief Architect Premier X12.
11 minutes ago, srjbb97 said:
Hello,
Manual or auto roofs?  If manual probably because the roof plane is going past the wall face and cutting it off.
If Auto most likely it is too close to the other roof plane and you will need to select the wall and change to roof cuts wall at bottom/if it continues as an interior wall below then it would need to be designated as what type of wall when cutting below instead.
