WildcatFury Posted November 17, 2020 Share Posted November 17, 2020 I have designed a one story house with a walk-out basement. The existing foundation walls in the basement are 8" with 3.5" wood frame and 1/2" drywall. The exterior walls on the 1st (main) floor are 6" wood frame with 1/2" drywall. My client wants to change the walls to ICF but maintain the same interior dimensions on the main floor. So am looking to change the main floor walls first then change the basement walls aligning them to the main layer of the walls above. My question is there a way to tell the new ICF wall to move out when I change the wall type, so I can maintain the same interior dimensions? Wall thickness with exterior finishes is changing from 10-7/16" to 15 1/2". Link to comment Share on other sites More sharing options...
rgardner Posted November 17, 2020 Share Posted November 17, 2020 Open up the ICF wall description and look at the options of where the platform builds to. Link to comment Share on other sites More sharing options...
WildcatFury Posted November 17, 2020 Author Share Posted November 17, 2020 Changing the General Wall specification to Resize about the inner surface did the trick. Thanks for the help Link to comment Share on other sites More sharing options...
