momsdesign 0 Posted October 13, 2020 Trying to replicate this wine area/glass walls. I know I can use poly lines to make the grids. BUT I need to show the client the room with doors open and doors closed. I looked on 3d warehouse and couldn't find much. I have tried to add lites to a door, but the frame of the door is still too thick. I need the black metal lines to be all the same thickness. Any suggestions would be amazing!! Thank you! Share this post Link to post Share on other sites
momsdesign 0 Posted October 13, 2020 I am also VER 12 if anyone needs to know. Share this post Link to post Share on other sites
solver 1569 Posted October 13, 2020 Windows. The Glass Panel door can be adjusted to show what you want -- I just didn't bother. 1 Share this post Link to post Share on other sites
momsdesign 0 Posted October 13, 2020 Well that is amazing, thank you so much! Share this post Link to post Share on other sites
momsdesign 0 Posted October 13, 2020 Do you know if there is any videos with the step by step directions to do this. I have only been doing Chief for 3 months. I tried doing windows and a door glass panel, but don't know how to change the look of the door to a thin black line. Guess I will keep trying. Also, how did you get this to be a corner! It's exactly what I need. Share this post Link to post Share on other sites
DzinEye 265 Posted October 13, 2020 2 minutes ago, momsdesign said: but don't know how to change the look of the door to a thin black line. 1 Share this post Link to post Share on other sites
solver 1569 Posted October 13, 2020 14 minutes ago, momsdesign said: Well that is amazing, thank you so much! Thanks. Don't forget to do your signature -- it help us help you -- check your messages for more info. 1 Share this post Link to post Share on other sites
solver 1569 Posted October 13, 2020 Just think through what you need to make this look correct. A wall to put the windows in. A single layer that's the color of the windows and the same width as the sash. Place a window. Remove what you don't want, add what you do. Check Window Defaults for Minimum Separation. It may need to be reduced. 1 Share this post Link to post Share on other sites
