How to create a grassy courtyard?
FireflyDesigns
  • 1 year later...
13 minutes ago, missionworks said:
create an outdoor space within my structure
CA still will recognize this as a room, so why not call it what it is, room type being a court.   Under the structure tab, by default the floor will be concrete slab, but you can change it to gravel/soil/grass or whatever.   Also set your floor elevation to what you want with main floor (-6 for example).  Uncheck roof over room and flat ceiling.. and "check floor under this room".  You might have to manually draw the foundation or maybe have to delete the slab it might create in this area.
