Willis93 Posted October 12, 2020 Share Posted October 12, 2020 Hello Looking for advice on how to put railings in a wall that has a doorway with an arched top. The issue is that when you insert a railing wall into a wall with an arched top it deletes the doorway along with the arched top and inserts the rails. In the attached pics to help explain. Any help or suggestions would be appreciated. Link to comment Share on other sites More sharing options...
Willis93 Posted October 12, 2020 Author Share Posted October 12, 2020 Thank you Solver I have noted your comments, however searching the forum is obviously a first choice. I have spent hours researching this, reading through posts, watching video, this was my last resort, so if you have any helpful ways to "solve" this problem please post them in addition to the copy and paste you did above. I am using x12 Premier. Thanks Jim! Link to comment Share on other sites More sharing options...
Willis93 Posted October 12, 2020 Author Share Posted October 12, 2020 7 minutes ago, solver said: Multiple ways. Draw railing wall off to the side. Make it No Room Definition, center in opening. Or make a railing symbol and place it in the opening. Thank you so Much! Seems so simple! Link to comment Share on other sites More sharing options...
mtldesigns Posted January 7, 2021 Share Posted January 7, 2021 Just had to do this.. making the railing off to the side and changing to a No Room Def worked perfectly. Link to comment Share on other sites More sharing options...
