Brad-Brad Posted September 17, 2020 Share Posted September 17, 2020 Warning: One or more of the views on the layout could not be updated because the original saved camera could not be found. I want this warning to go away. Through my investigation, I have 9 cameras on my working plan view, 9 cameras in my project browser under cameras and cross sections, and I have 9 image views in my layout pages that I am using. In other words, all the cameras in my plan match up to all the cameras in my layout. Yes, I may have deleted a camera but none that were needed. I cannot find any blank image views in any of the pages of my layout either. Am I stuck with this warning every time I update or print preview other than checking the box? And in that case will it affect anything else that matters? Link to comment Share on other sites More sharing options...
Dermot Posted September 17, 2020 Share Posted September 17, 2020 You probably deleted a camera from your plan that the layout is still using. The easiest solution is to delete the layout box that was referencing the camera. To find the layout box, turn on your layout box borders layer and look for the blank box. If you have trouble finding it, then you might want to post the plan and maybe someone will be willing to help. If all else fails, then you might also consider contacting technical support. Link to comment Share on other sites More sharing options...
Brad-Brad Posted September 17, 2020 Author Share Posted September 17, 2020 Awesome, turning on the layout box borders layer worked. I found the blank layout box. Thank you so much. Link to comment Share on other sites More sharing options...
