Sign in to follow this
gtlackey
Adjusting grid under imported terrain
Once I have imported and rotated a terrain file, how can I adjust the grid under it so when I start the build that process will be squared.
I can rotate the terrain file so when adding the house I am building out front to back, but when I do that the grid is angled underneath, so snap to and cursor boxes are all angled due to the terrain rotation?
It sounds like you used Rotate Plan View - bad move.
Read up on Rotate Plan View and don't use it - except to rotate your terrain back to zero degrees.
Then use Edit Area to do the rotation.
    28411
    LFDesign
    LFDesign
