rockyshepheard Posted September 5, 2020 Share Posted September 5, 2020 Is there a way to modify the railing on a deck...spacing, height, shape, etc. When I click on the room I don't see "railing" listed. ROGER CHANGES 02.plan Link to comment Share on other sites More sharing options...
Ridge_Runner Posted September 5, 2020 Share Posted September 5, 2020 Double click on the railing walls you want to change (usually better to adjust the railing wall defaults before you draw any railing walls; you can then save them in your user library for reuse). The dialog box that opens up is where you set the items you wish to change. The "room" sets things like the height of the ceiling and any floor structure. Link to comment Share on other sites More sharing options...
