kwhitt Posted September 5, 2020 Share Posted September 5, 2020 I need to create an isometric view of a floating shelf for the cabinet shop. It consists of 5 parts with a hollow core. When I create a vector view it appears as one solid piece as the mitered edge lines don't show. Is there a way to get Chief to show all these lines? Thanks! Link to comment Share on other sites More sharing options...
Dermot Posted September 5, 2020 Share Posted September 5, 2020 Try making the inside piece a different material. It doesn't actually need to look different, it just needs to be assigned to a separate material. So all you need to do is make a copy of the other material. 1 Link to comment Share on other sites More sharing options...
kwhitt Posted September 5, 2020 Author Share Posted September 5, 2020 7 minutes ago, Dermot said: Try making the inside piece a different material. It doesn't actually need to look different, it just needs to be assigned to a separate material. So all you need to do is make a copy of the other material. Thanks Dermot. Works Great! Link to comment Share on other sites More sharing options...
