rfantclt Posted August 31, 2020 Share Posted August 31, 2020 I am trying to make a custom column that has a brace at the top (required due to height). I have drawn the shapes I want and the center portion (the exposed structural column) easily converted to a polyline solid. When I try to convert the the two polyline curved braces into a polyline solid, it only gives me the option to make them polyline moldings. Attached is the Column brace.plan file and a pdf of what the overall column needs to look like. I'm using X12. Thanks for help figuring this out! Rebecca SK-Draft - Column Dtl 2020_0831.pdf Column brace polylines.plan Link to comment Share on other sites More sharing options...
rlackore Posted August 31, 2020 Share Posted August 31, 2020 The polylines need to be closed. First, clean things up a bit - the left brace has some extra lines - then select all the lines and make certain they all have identical properties (Line Style tab). In this screenshot, you can see that the lines don't have the same Weight: After you've made the lines identical, then they will "close" properly, and you will get the option to convert them to a polyline solid. 1 Link to comment Share on other sites More sharing options...
