Steve_Nyhof Posted August 26, 2020 Share Posted August 26, 2020 I was messing around with my template wanting to get some more things in place for my stairs and defaults. I ran into this before and just moved on, but now I am drawing homes using Chief and need to find a way to angle or follow the stairs with a halfwall. Thank you SND_D_Residential Template.plan Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted August 26, 2020 Author Share Posted August 26, 2020 The follow stairs is checked - still looking... Link to comment Share on other sites More sharing options...
GeneDavis Posted August 26, 2020 Share Posted August 26, 2020 Make the wall a solid railing wall, the do the Solver expedition through the specs. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted August 26, 2020 Author Share Posted August 26, 2020 It is a solid wall Link to comment Share on other sites More sharing options...
GeneDavis Posted August 26, 2020 Share Posted August 26, 2020 Tight? If wall is 4.5", stair sections need to be that space apart. No Chief 4 me right now. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted August 26, 2020 Author Share Posted August 26, 2020 I think it may be because I have a halfwall on the top floor - I may need to turn my lower wall into a solid rail - trying that now Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted August 26, 2020 Author Share Posted August 26, 2020 Ah! I think I'm getting somewhere Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted August 26, 2020 Author Share Posted August 26, 2020 I'll keep working on it. The cap is on the lower stairs but the wall is following the higher stairs also without a cap. Doing it this way only shows the wall on the lower floor and blank on the upper. I'm still digging... Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted August 26, 2020 Author Share Posted August 26, 2020 Wow! I think I just did it by adding a solid rail wall on the lower floor. It still only shows the wall on the lower floor and not on the upper floor. Maybe I'll try a pony wall. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted August 26, 2020 Author Share Posted August 26, 2020 So I think I have a process now. The lower floor needs the halfwall (solid rail) follow the stairs. The top floor does not show a wall - I even made a pony wall and tried the options to go thru floor, etc. Then I added a small return of the wall where the halfwall meets the stairs on the top floor - this completed the wall. Then i was able to put the angled wall up under it. I think it looks good in plan view and 3D. Link to comment Share on other sites More sharing options...
GeneDavis Posted August 26, 2020 Share Posted August 26, 2020 The top wall should run all the way across the stairwell. The stairs will create the opening, and you'll like your wall junction. Link to comment Share on other sites More sharing options...
