Adam_Gibson Posted August 21, 2020 Share Posted August 21, 2020 Hi all, I thought I'd have an easy handle on this but I'm a bit stumped. This entire existing house is two stories. The proposed family room is currently a courtyard. I want to enclose it and put a one-story family room with a roof that drains to the one outside corner. I'd rather avoid an internal drainage system because I don't think it's necessary. But for the life of me, I can't figure out how to draw the roof pitches. I'd probably do a 1/12 pitch because of the second-floor windows that look out onto the current courtyard. I'd be grateful for your suggestions. I posted the entire pan in case anyone wants a closer look. Untitled 2.zip Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 21, 2020 Share Posted August 21, 2020 You will need a very low pitched roof slanted towards the only corner where it can drain to. I would do this manually using about a 1/16/12 pitch. It is a definitely head-scratchier. DJP Link to comment Share on other sites More sharing options...
Adam_Gibson Posted August 22, 2020 Author Share Posted August 22, 2020 Eric and David and Glenn, thank you so much! I really appreciate your responses and your dedication to helping. Solved! Link to comment Share on other sites More sharing options...
