interior walls show siding
josbrp
1 hour ago, rlackore said:
For the far wall, you need to align the wall below with the wall above; then drag the roof edge against the upper wall, then your setting should work:
I think im doing something wrong because my walls dont change after aligning them and fixing the roof.
mac111111.plan
mac111111.plan
Select the roof plane on the first floor and move it up to the second floor, then select the relevant edge and drag it against the 2x6 exterior wall that is aligned with the wall below. You can then move the roof plane back down if you want.
