Apollosg Posted August 18, 2020 Share Posted August 18, 2020 I am trying to understand the labeling system in CA. If I add a new device, I can create a label a half dozen different ways, and all of them seem to work. If I decide to create a schedule with that item, still no problem. As soon as I add another item to the plan, which is then included in the schedule, the labels change to schedule labels generated by CA. I can't seem to turn them off in any form that still allow the original label to be displayed. Is there a trick to removing the schedule labels from the layout. I am trying to perform an as-built system inventory of a customer's site. They want an equipment schedule and this seems like it should be easy enough. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 18, 2020 Share Posted August 18, 2020 Sounds like you need to be sure this is turned off: 1 Link to comment Share on other sites More sharing options...
Apollosg Posted August 19, 2020 Author Share Posted August 19, 2020 @ChopsawThank you so much, that did the trick. 1 Link to comment Share on other sites More sharing options...
