Apollosg Posted August 4, 2020 Share Posted August 4, 2020 I have a wall on the back of the garage - 2nd floor that is not framing. I didn't notice it until I tried to place a window in the wall and the stud wont go away. Can someone help me out with this? Window_Problem.zip Link to comment Share on other sites More sharing options...
Chopsaw Posted August 4, 2020 Share Posted August 4, 2020 Check the Wall DBX under the Structure Tab and see if "Retain Wall Framing" is selected. Link to comment Share on other sites More sharing options...
Apollosg Posted August 4, 2020 Author Share Posted August 4, 2020 @Chopsawthat is not checked on either floor. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 4, 2020 Share Posted August 4, 2020 You seem to have it balloon framed from the wall below. P.S. You have a lost Iron Cross out at X 5778" and Y 18773" on level 2 that is messing up your cameras. Link to comment Share on other sites More sharing options...
Apollosg Posted August 4, 2020 Author Share Posted August 4, 2020 @Chopsawthank you, I did see the ballooning and turned it on and off with no change in effect. I am starting to wonder if it is because part of the garage is open below. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 4, 2020 Share Posted August 4, 2020 Yes the garage and stairwell will need to be balloon framed. So leave that as it is and then you may need to do something different for the stair landing. The point is that the framing is controlled by that wall and will need to be re-framed from the wall below to frame for the new window. However it seems that for that wall to recognize the window it will need to be placed in the level 1 wall. Likely the easiest way to do that is in 3D from Level 2 set the window to an absolute elevation and then CTRL + X it, then move to Level 1 and CTRL + ALT + V it back into place. You have auto frame turned on so that should fix it. Link to comment Share on other sites More sharing options...
Apollosg Posted August 4, 2020 Author Share Posted August 4, 2020 I changed the structure on the lower wall to stop at the ceiling above and it seems to have fixed it, but the upper and lower framing did not seem right. I did what you said and all looks good. Thank you. I did see that cross at the coordinates, but not sure what it is. How do I get rid of that, if its a problem? Thank you for your time @Chopsaw Link to comment Share on other sites More sharing options...
Chopsaw Posted August 4, 2020 Share Posted August 4, 2020 3 minutes ago, Apollosg said: I did see that cross at the coordinates, but not sure what it is. How do I get rid of that, if its a problem? It can be selected and moved or deleted so it does not effect your camera setup. Link to comment Share on other sites More sharing options...
