ACADuser Posted July 28, 2020 Share Posted July 28, 2020 I noticed that the leader line weight for new leaders is set to 35 & the use default is unchecked for new leaders. This also happens in section views. I am trying Saved plan Views for the first time and wonder if that is causing the issue? Largo TH 2 plex.zip Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 29, 2020 Share Posted July 29, 2020 That line style is actually controlled by your Active Rich Text Defaults>Appearance>Border. You'll have to temporarily check Border to change the settings. Link to comment Share on other sites More sharing options...
ACADuser Posted July 29, 2020 Author Share Posted July 29, 2020 Wow, had no idea the leader was tied to the border. But I can see why to might want the leader to match the border IF you checked the border! That did fix it though. Thanks Link to comment Share on other sites More sharing options...
ACADuser Posted July 29, 2020 Author Share Posted July 29, 2020 I assume there is no way to turn this behavior off. i.e. If the border box is not checked use the text layer line weight? The reason I have it set at 35 is that ocausanally I turn the border on and then I want it to be 35. Link to comment Share on other sites More sharing options...
