Jambruins Posted July 16, 2020 Share Posted July 16, 2020 How do I get the bottom of the stair landing to close? I changed the floor height of the room to 48" but then it leaves an open section into the house. Link to comment Share on other sites More sharing options...
Jambruins Posted July 17, 2020 Author Share Posted July 17, 2020 I have tried adding a wall but it doesn't work. I selected the room and in the room specifications under structure I changed the floor height to 48". If I change this back to 0" the wall gets closed but the owner does not want the wall to extend to grade. They want to frame in a landing for the stairs so there will be about 48" of room below the landing on the exterior. Link to comment Share on other sites More sharing options...
Bergford Posted April 7, 2021 Share Posted April 7, 2021 Jambruins where you able to solve this? I have the same issue. On 7/16/2020 at 9:08 PM, solver said: A wall? Expand solver Please tell us more. how to draw a wall under the stair landing. Link to comment Share on other sites More sharing options...
Bergford Posted April 7, 2021 Share Posted April 7, 2021 I created a balcony room at the same floor height as the stair landing inside, which is 67". I have tried to turn the foundation into a pony wall and it makes a mess... I have tried to break an adjacent wall and drag it under the landing/balcony but it isn't allowing me to break the wall... Any other suggestions? I would like to draw a wall under as you suggest but There is already a wall occupying the 2d space... I tried checking the box roof splits wall / lower wall. maybe chief thinks the balcony is a roof but that didn't work either. Link to comment Share on other sites More sharing options...
Bergford Posted April 7, 2021 Share Posted April 7, 2021 If I drag the wall across the balcony it fills in the area under the balcony but then remove the wall above the landing. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 7, 2021 Share Posted April 7, 2021 Try drawing a wall and changing it to No Room Definition and then place it in position and you should be able to edit it in elevation view to fill the space. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 7, 2021 Share Posted April 7, 2021 Yours will look much better but here is the concept. Link to comment Share on other sites More sharing options...
