winterdd Posted July 15, 2020 Share Posted July 15, 2020 Hey guys, can we not set the window sizes and make a roof and bottom in the settings as shown in the pics? Link to comment Share on other sites More sharing options...
glennw Posted July 15, 2020 Share Posted July 15, 2020 To change window size, select a wall of the box and then Tab to select the window. I think you will need a manual roof (or something else like a polysolid) and a solid or similar to do the bottom shape. Link to comment Share on other sites More sharing options...
winterdd Posted July 15, 2020 Author Share Posted July 15, 2020 21 minutes ago, glennw said: To change window size, select a wall of the box and then Tab to select the window. I think you will need a manual roof (or something else like a polysolid) and a solid or similar to do the bottom shape. tried that but its a block. it doesnt show where it can be exploded to manipulate anything. Link to comment Share on other sites More sharing options...
glennw Posted July 15, 2020 Share Posted July 15, 2020 You don't need to explode anything. Select the bay by one of it's walls. Hit Tab and the window in that wall will be selected. Open the window for editing. Link to comment Share on other sites More sharing options...
winterdd Posted July 15, 2020 Author Share Posted July 15, 2020 you are correct. i found that clicking on the wall around the window doesn't work. you have to click on the actual window itself for the tab button to find it. thanks Link to comment Share on other sites More sharing options...
