How to change automatic placement of electric outlets
capitaldesigns
I was using the automatic placement of electrical outlets in an addition project.
CA 12 is placing GFCI outlets in all room types, bedrooms, bathrooms, family rooms, etc.
Is there a way I can change this automatic feature to place GFCI outlets in only bathrooms,
kitchens, laundry rooms and garages ?
Thanks,
Mike
Thanks,
Mike
It shouldn't be doing this unless you changed your default outlet to a GFCI. Check your defaults\electrical\general electrical\ and if that isn't the issue, your rooms are not designated but simply named.
