capitaldesigns Posted July 10, 2020 Share Posted July 10, 2020 I was using the automatic placement of electrical outlets in an addition project. CA 12 is placing GFCI outlets in all room types, bedrooms, bathrooms, family rooms, etc. Is there a way I can change this automatic feature to place GFCI outlets in only bathrooms, kitchens, laundry rooms and garages ? Thanks, Mike Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 10, 2020 Share Posted July 10, 2020 44 minutes ago, capitaldesigns said: I was using the automatic placement of electrical outlets in an addition project. CA 12 is placing GFCI outlets in all room types, bedrooms, bathrooms, family rooms, etc. Is there a way I can change this automatic feature to place GFCI outlets in only bathrooms, kitchens, laundry rooms and garages ? Thanks, Mike It shouldn't be doing this unless you changed your default outlet to a GFCI. Check your defaults\electrical\general electrical\ and if that isn't the issue, your rooms are not designated but simply named. 1 Link to comment Share on other sites More sharing options...
