Callouts disappear on Plan when Convert Schedule to Text
DeltaHome
Regardless of where I do it (either on the plan itself or in a CAD Detail) when I convert schedule to text my callout symbols disappear on plan view and are replaced with automatic labels.
I assume that convert schedule to text is causing this.
I need to insert text under the comment column.  Is there a way to insert text in a schedule under the comment column without converting the schedule to text?
What is the best way to insert text for instance under my comment column in a schedule?
  On 7/5/2020 at 11:29 PM, DeltaHome said:
2 Beers for you.
Thank you.
Expand
Keep in mind that once you 'convert to text' it is no longer an actual schedule. If you prefer to use the text box, create a copy of the schedule, then convert that copy to text. Just make sure you do NOT end up with multiples of the same 'live' schedule.
