Exterior staircase not displaying in first floor.
ChiefWariq
Hi Guys, I have a problem that I've been trying to solve but just cant figure out, i'm hoping you guys can lead me in the right direction.
I have a set of exterior stairs that leads to the second floor living space. These stairs serve as the main staircase to the entrance of a duplex that i'm developing on my property. In plan view, I can see the stairs just fine when im on the second floor, but when I toggle down to the first floor, I can not see the outline of those stairs. I've tried for multiple hours, rummaging through settings, building them in different levels and can't get it to display. What am I doing wrong?
I'm new to the application and i'm loving it so far. Thanks for any help in advance
Thanks for the reply Solver, I went back and deleted the stair case and created the stairs from the first floor UP. I also created the landing on the first. I turned on reference display and can see the staircase when in the second floor now, in red. Now, is there a way to make the staircase look just like in the first floor but with a down arrow? (in black as well?) Similar to the image here.
This was my original staircase that i built on the second floor but wouldnt appear on the first. Thanks a lot for your help, and sorry to bug.
Remove the CA arrow in the stair dbx and add a manual one - easy to control that way. Put it on a layerset that you want off in other views but can be turned on in your reference layerset.
